25mm Stainless Steel pipe bending to make a 3 bar Bimini
rogerthebodger
3 Nov 2001
I made the exact type of bimini using a horizontal pip bender as you don't get the issue of running out or room you get with a vertical bender like the one you shown.
This is the type of bender I use
Works well bolted to a bench bolted to a concrete floor or wall
dgadee
13 Oct 2010
Whenever I needed bends I would pay the £10 per bend at my local SS man. Now moved. If you know of anyone in Edinburgh area who does stainless work I would be pleased to hear.
Thistle
2 Oct 2004
Here
Is there not someone at Port Edgar?
Aye, but they refuse to do any work on boats regardless of whether they are afloat or on the hard. They'll make up things to your specifications if they can be made from standard stock.
I wanted a new chainplate in 5*45mm stainless with 3 bends and 8 holes drilled. They wouldn't go aboard to measure and could only offer to do it in 5*50mm. I can't recommend them.
