Refueler
Why if the coppercoat hasn't worn through? Surely what you are saying is don't buy a second hand boat that is coppercoated because you can't be sure of the prep.
That is NOT what I read from AP's post.
Coppercoat is very slightly porous, so if the gel coat was damaged you'd have to replace the Coppercoat BEFORE it was worn through.Why if the coppercoat hasn't worn through? Surely what you are saying is don't buy a second hand boat that is coppercoated because you can't be sure of the prep.
So how do you tell if you are buying a second hand, coppercoated, boat?Coppercoat is very slightly porous, so if the gel coat was damaged you'd have to replace the Coppercoat BEFORE it was worn through.
Damage to gel coat is carefully avoided by professional blasting, so it would only be an issue for DIY work. Further, I'd expect damage to the gel coat to be made good before applying Coppercoat - say by applying an epoxy primer.
Coppercoat depends entirely on good preparation.
Being in Scottieland, Coppercoat advise blasting in winter and waiting for warmer weather in early summer. Lets the hull dry out a bit and ensures correct weather for application. So it is obviously sensitive to application conditions.
Failure usually manifests itself by poor adhesion and the coating coming off. It also may require refreshing by abrading with a Scotchbright pad from time to time if it starts to lose effectiveness. After typically 10 years+ it may need recoating which does not require removal of the old, just flatting down and re-application. So if it is still attached to the boat and you get an idea when it was applied you can make reasonable assumptions about its future life. GRP hulls are rarely a problem as any adhesion failure shows up pretty quickly after application. The real weakness is getting it to stick to cast iron keels because of the difficulty of getting the iron clean and free of impurities. Good blasting (not grinding) and immediate coating with epoxy is critical. On old corroded iron keels it may be sensible to use one of the long life (2-3 years) antifouls rather than Coppercoat.So how do you tell if you are buying a second hand, coppercoated, boat?
I appreciate responses, thank you.
Thanks, so if it's stuck it doesn't matter if the gwl coat was blasted through in places? Good to know.Failure usually manifests itself by poor adhesion and the coating coming off. It also may require refreshing by abrading with a Scotchbright pad from time to time if it starts to lose effectiveness. After typically 10 years+ it may need recoating which does not require removal of the old, just flatting down and re-application. So if it is still attached to the boat and you get an idea when it was applied you can make reasonable assumptions about its future life. GRP hulls are rarely a problem as any adhesion failure shows up pretty quickly after application. The real weakness is getting it to stick to cast iron keels because of the difficulty of getting the iron clean and free of impurities. Good blasting (not grinding) and immediate coating with epoxy is critical. On old corroded iron keels it may be sensible to use one of the long life (2-3 years) antifouls rather than Coppercoat.
The blasting through the gel coat is a bit of a red herring. Nobody in their right mind would Coppercoat without filling and fairing. It is common for blasting to remove all or part of the gel coat on older boats with blistering damage from osmosis followed by filling and epoxy before applying any other coating.Thanks, so if it's stuck it doesn't matter if the gwl coat was blasted through in places? Good to know.
Thanks for reply.The blasting through the gel coat is a bit of a red herring. Nobody in their right mind would Coppercoat without filling and fairing. It is common for blasting to remove all or part of the gel coat on older boats with blistering damage from osmosis followed by filling and epoxy before applying any other coating.
The blastig throu
Abrade and re coppercoat at the spot. If you had a real problem with adherance you would have known by now. You could apply some epoxy primer before the CC if you want.Thanks for reply.
So, if like me, you have bought a second hand boat, coppercoated in 2016, which looks perfect and still works well. But the occasional (once every couple of years) fifty pence bit sized piece of coppercoat flakes off and all you can see underneath is supersmooth csm you shouldn't worry?
Coppercoat shouldn't be flaking off; that sounds like bad preparation; mine has been in place for 10 years with no sign of flaking except on a cast iron keel, which even AMC will tell you is to be expected. I suspect it has been applied to a hull that wasn't allowed to dry before application. If you can see CSM that's bad! It that water can get into the laminate, wicked along the glass strands. If I were you I'd be looking at stripping back to GRP or gel coat, allowing the hull to dry out for several months and then coating with an epoxy coat followed by Coppercoat or antifoul of your choice.Thanks for reply.
Our opinions differ slightly. Depends how much you want to spend.Coppercoat shouldn't be flaking off; that sounds like bad preparation; mine has been in place for 10 years with no sign of flaking except on a cast iron keel, which even AMC will tell you is to be expected. I suspect it has been applied to a hull that wasn't allowed to dry before application. If you can see CSM that's bad! It that water can get into the laminate, wicked along the glass strands. If I were you I'd be looking at stripping back to GRP or gel coat, allowing the hull to dry out for several months and then coating with an epoxy coat followed by Coppercoat or antifoul of your choice.
Two or three of us are planning to Coppercoat. One of the three suggested a diy approach. I am not enthusiastic having heard negatively from a friend (now sadly dead) who tried it but can't remember what he said.
What are the arguments against this approach if you have tried it? Skill level is my main concern given that to do it properly you would be working with powerful equipment on a thin get coat. I can see the positive - it could be cheap.
It had a couple of coats of epoxy prior to coppercoat but don't know if it's transparent.Coppercoat shouldn't be flaking off; that sounds like bad preparation; mine has been in place for 10 years with no sign of flaking except on a cast iron keel, which even AMC will tell you is to be expected. I suspect it has been applied to a hull that wasn't allowed to dry before application. If you can see CSM that's bad! It that water can get into the laminate, wicked along the glass strands. If I were you I'd be looking at stripping back to GRP or gel coat, allowing the hull to dry out for several months and then coating with an epoxy coat followed by Coppercoat or antifoul of your choice.
Seems a bit drastic for one 50p piece sized bit flaking off every couple of years, when it's been on 8 years.Coppercoat shouldn't be flaking off; that sounds like bad preparation; mine has been in place for 10 years with no sign of flaking except on a cast iron keel, which even AMC will tell you is to be expected. I suspect it has been applied to a hull that wasn't allowed to dry before application. If you can see CSM that's bad! It that water can get into the laminate, wicked along the glass strands. If I were you I'd be looking at stripping back to GRP or gel coat, allowing the hull to dry out for several months and then coating with an epoxy coat followed by Coppercoat or antifoul of your choice.
Get a repair kit from AMC to do the patches. Looks a bit messy when you do it, but soon blends in when the boat goes back in the water. Photo shows patches on the keel of by BavariaSeems a bit drastic for one 50p piece sized bit flaking off every couple of years, when it's been on 8 years.
