Benny81
Hi, My dinghy came of its trot rope over the weekend. What's the best knot(s) to use? Any help greatly appreciated
If in doubt, use a bowline.
Thanks Refueler I'll try that, and yes it's a modern synthetic rope
Sorry if my post wasn't clear
Pedant
Should it be a Prussic knot, not a prussic knot? As it should be a Barber haul not a barber haul?
Is it important?
Do you use a delta anchor, rocna anchor or a Supreme or Bugel?
jonathan
Exactly what I always did, put a turn over the top loop. Securely held many tens of thousands of straw and hay bales only single axle trailers this way on some very steep slopes here in Cornwall. Never lost a load. I would disagree with the "serious rope handlers" quote. If done properly it is a quick and sound way of making a further 2:1 reduction, It can also be untied with ease ready for the next load. As I said, the absolute mainstay of securing loads before ratchet straps.OK ... Clove Hitch can tighten and seize when left long term / have tension snatching at it. At times it can lead to the use of sharp knife to get free ....
I am dead against Cow Hitch normally as its what it says ... a COW hitch and has very few uses in serious rope handlers inventory. BUT it can be used in this by making sure at least 2 half hitches securing free end are made back onto the stranding part. Beware - without 2 HH to secure - a Cow hitch was based on halving a rope in use such a Bulls Ring to give two ropes to control if needed ... not to secure and only use one rope end.
