Boo2
Most of the davits I've seen permit an angled out installation, is there a reason that won't work on your Centurion ?...Unfortunately I cannot because the transom is too narrow...
Boo2
Thanks for the feedback re the Plastimo davits. One specific question - I believe they can be rotated, but can they be easily removed when not in use?
IIRC they just lift out of their sockets so yes.
Boo2
A lot of people don't like to tow a dinghy and warn against it. I have never done so and intend to fit davits to my 34 foot boat rather than try it.
Boo2
IIRC most makers prefer you to mount them slightly angledout such that the lifting tackles pull against each other, preventing sideways movement.Most of the davits I've seen permit an angled out installation, is there a reason that won't work on your Centurion ?
Boo2
Boo2
As long as you take the outboard and oars off, towing a rubber dinghy is rarely a problem on coastal sailing. We have towed one many hundreds of miles, sometimes in pretty rough conditions with minimal issues. Think flipped twice in 10 years, when very badly provoked - and simply hove to and flipped back with boat hook. You should try it before assuming it would be a problem.
But clearly there is some extra drag hence why interested in davits.
Boo2
Not enough transom width on most boats until you get towards 40'.
Unfortunately I cannot because the transom is too narrow (Centurion 32) and Murphy now lives upside down on the foredeck, ready to be launched with the spi-pole serving as a jib (or 'sheer leg') the lifting / lowering being via the storm-jib halyard.
I can see that the height of the top of the transom matters (actually the height of the base of the davits but normally I guess that's the same thing) but not the width of it ?You may well be able to do this, but the problem with low narrow transoms like the one in question is that the dinghy overhangs the width so much and is so low that it hits the water if the boat is heeling. Another reason why davits are more common on larger boats with wider and higher transoms, like the Westerly mentioned earlier.
Interesting a couple of people mention the inflatable floor type dinghies. I started out with one of these. Unfortunately I found it a serious mistake. The biggest problem I had was finding a way of "fixing" attachment points for the davit wires. I tried various arrangements but could never pull the dinghy so that the tubes were tight against the davits.....
