digital tv on board
andyball
1 Jun 2001
after rubbish reception with a saucer aerial branded "weekend super" & needing a new tv since boat original only picks up foreign programs, we've been down the flatscreen/new aerial/freeview road.
Old aerial was easily improved upon by replacing it with a short length of wire, which splendidly even allowed freeview to work, as long as the tide wasn't too low. This made us laugh at our many home neighbours who've laid out £100's for "freeview" aerials after local installer presumably told them it was vital.
Now replaced with Status 315 omni-directional one (cheaper at towsure, £90-95 at local caravan shops), which is a great improvement, but think a directional one wd be better if you only wanted telly in a marina berth so could point it the right way.
Now find analogue channels reliable, but ghosty picture; freeview superb picture/sound, except some channels at low tide. Will replace old/rubbish cable next.
Found a combined lcd/freeview tv, so no separate box, which made fitting easy (check that it receives analogue too, if you might ever need it to...) & wall mounted it using a £25 bracket from <A target="_blank" HREF=http://www.chaseavdirect.co.uk/acatalog/LCD-Mounts.html>chase av direct</A> which is removeable yet can be locked into place with a long allen key. bracket could do with extra wall mounting screw holes if into thinnish ply, but there's room for this.
So now have cool widescreen tv, wife v.pleased as she could watch sunday's grand prix in style, now wondering about using the pc monitor ability to show a chartplotter screen.
Good innit?
But we beat you by at least five years on our old boat in the UK!
Steve Cronin
<hr width=100% size=1>The above is, like any other post here, only a personal opinion
andyball
1 Jun 2001
john lewis store had a freeview only 15" & a freeview/analogue 17" widescreen ....<A target="_blank" HREF=http://www.johnlewis.com/stores/multiproduct.asp?shelfid=17441&str=131&Configurator=0&trsid=2643&m=-1>here</A> & ah, the humax isn't on their website yet.
& Steve.....yes it is good, we'd have got one before but thought it'd be a bit too much on a 6m sportsfisher.
The mounting brackets are expensive most places...my £25 one was up to £50 elsewhere.
WoW!
£500+
That IS serious money just to keep up with (the?) Neighbours and Eastenders.
We just took the onDigital box to the boat and used a cheap inverter.
Now based in Corfu, we do have a Greek TV but it's only a B&W 4.5" portable. Language getting better slowly but all the films are American with sub-titles leaving the english soundtrack intact so no problem. Reception on a telescopic is very good as Greece is served by multiple relay stations to coverall the islands.
Steve Cronin
Wiggo
10 Sep 2003
In front of the bloody computer again
Re: WoW!
Nah, these to go with it, but the beauty is they're both 12V DC, so no inverters. Picture is superb, BTW.
<hr width=100% size=1><A target="_blank" HREF=http://homepage.ntlworld.com/graham.wignall/boats/eulimene600x800.jpg>The old and the new</A>
ayms
22 Apr 2004
London / Solent
Re: WoW!
I have been looking for a LCD TV for 12v for some time. I had resigned myself to having to install a full time 600w inverter but maybe I was jumping the gun.
Both your links appear to go to the same place.. Was one supposed to be a DVD player per chance ?
How many amps does the TV draw ? Are you using an amplified TV antenna ?
Aymsley
<hr width=100% size=1>Doing the Arc ? Me to on www.makathea.co.uk
Robin
30 May 2001
high and dry on north island
Re: WoW!
We have an excellent Bush LCD 15" TV which runs direct on 12v (or 220v mains or via inverter). It is available from Argos, we actually got ours 'free' with Nectar points. It is a multi-standard PAL/SECAM set that will work everywhere (many if not most do not work in France for example) and the 12v connection is a simple female phono type connector, in our case the same one that we used for our old 6" B&W set. Beware some LCDs are nominally12v via their supplied AC/DC adapter but the connector is a multi pin special not easily obtained and some (Sharp Aquos) say that direct running on 12v negates the warranty, you must use an inverter.
Wiggo
10 Sep 2003
Re: WoW!
sorry, one was to the 17" Relisys LCD TV (£399) and the other was to the Strong 5000 DVB box (£40). TV draws a claimed 5A max (the wall wart is rated 12VDC, 5A).
