mullet
My boat's has a welded ~45l stainless diesel tank, probably as old as the boat (pushing 40 years), and the welded seams are failing causing it to leak. I'm considering repairs vs replacement. Any consensus (ha!) on whether it is worth trying to repair a stainless tank, or would this be a case of throwing good money after bad?
The boat is a GRP Twister and the tank is in a cockpit locker, mounted on the locker's forward bulkhead; there are no other sensible locations elsewhere on the boat for a fuel tank the same size, but a replacement could be fitted in the same locker, potentially in a more practical way. Other factors/questions:
- The engine is a Beta 14 and gives decent boat speed at low revs, so it is not exactly a gas guzzler. A smaller tank plus supplementary fuel in cans could be practical.
- Internal inspection of the current tank is impossible (it is mounted horizontally, as high as possible on the forward bulkhead, to make use of the area of widest beam). And it has no fuel gauge. A lower installation would allow inspection access, offer a (small) CoG improvement and would not affect the engine (which doesn't need gravity feed). Any obvious downsides, beyond potentially needing an odd-shaped tank to maximise use of space?
- Plastic tanks. I am attracted by less condensation and no welds to fail. Any cons beyond being limited to manufacturers' sizes/shapes?
- The existing tank has flanges for bulkhead mounting. I've not seen this on any off-the-shelf tanks. If not bulkhead mounted, is there a recommended way of fixing the tank in place? Should I be looking at adding a shelf for it to sit on? Strapping it down?
- I am considering installing a diesel air heater (Eberspracher or similar) to the boat which might affect choices about the tank (size and location). The convenient location for the heater would be elsewhere in the same locker. Bad plan to put a combusting device in the same locker as the diesel or generally seen as acceptable? If a terrible idea I'll factor this out of considerations.
