matnoo
Being in the wash and not having much experience is good because it forces you to toutch up on your navigation skills, and also that you can only possibly hit sand!
The bad bit is that you (or I) tend to hit sand more often than id like and then get stuck...
In addition to practising my dislodging skills I have decided to build two legs for my boat. On the topsides there are already two large reenforced holes (adjacent to a bulkhead) with two 12mm stainless steel bolts through them which when removed are for fitting legs onto.
Any suggestions? Obviously then need to have a 12mm bolt as a fixing, but it would be good if they were adjustable. Im fine with wood, and plastic (I prototype products in both all the time for my job), but not metal as i cant weld, so metal tube isnt possible.
Before I start drafting my own ideas, are there any simple methods that you know of?
Shes only a little thing, 23ft fin keel so doesnt need tree trunks.
ta
Mat
ta
Mat
