vyv_cox
The galvanising on Spade anchors is notoriously poor. An advantage you have in Turkey is that having it regalvanised may not be too much of a problem but you will need to have its lead ballast melted out first.
Yes mine is filthy rusty at the moment and that's mainly why i think the shaft is weak where it's holed for the shackle.The galvanising on Spade anchors is notoriously poor. An advantage you have in Turkey is that having it regalvanised may not be too much of a problem but you will need to have its lead ballast melted out first.
Thanks. I hear what you're saying about getting the Spade shank repaired and getting the whole thing re-galvanised but, honestly, I'd always have a concern about the repair and I'd rather sleep at night than worry. I'd definitely buy another Spade if I could get one in Türkiye.Thanks for clarifying.
The steel Spade is an excellent anchor, which explains your previous positive results.
You mentioned in your first post concerns about corrosion weakening the shank. It would be worth investigating how much actual material has been lost, and if re-galvanising the anchor is a possibility. Often rusty parts look worse than they are in reality. Unfortunately, re-galvanising a Spade is more involved than most anchors. The lead has to be removed and then reapplied after galvanising, but labour is not expensive in Turkey and there are many small engineering firms prepared to do this type of work. The steel Spade has a fabricated (probably mild steel) shank so a local welder may be able to repair any lost material. As the Spade is a good and expensive anchor, the possibility of re-galvanising is at least worth looking into.
If the anchor does need replacement I would be even more reluctant to step down to a lower performing model such as the Delta. The M2 would be much better. Unfortunately, I have not seen enough of the M2 underwater to decide if it is slightly better or worse than the steel Spade so I cannot give you a definitive answer on the relative performance you are likely to experience. Another data point is Panope’s excellent anchor tests. In these tests the M2 has done better than the steel Spade and the M2 users I have spoken to have all had positive feedback so I think you are unlikely to be disappointed.
, to understand that @Neeves pretty much rates Mantus as scrap metal.
I have to admit a lot of the science is beyond me.
I've been very happy with my Spade anchor - even if I thought it was a Delta -
Thanks again for all the advice. Much appreciated. I'd rather be boating than researching so I'm happy to listen to experts and combine their opinions with my own experience and instinct. Spade it is, if I can find one, and, if not, I may just defy my inner miser and buy an Ultra.Even I might suggest a little bit of research would do you no harm. Not everything that is published, on anchors, is sound
Jonathan
I had a similar thing with a copy CQR. The original genuine one set well and held until it snagged something on the bottom and refused to let go - it's still there. I never did get the copy to set. I replaced it with a Delta that gave sterling service for 15 years, dragging just once, in mud soup in Newtown Creek, a place with notoriously iffy holding. Jazzcat came with a Danforth and a special mounting for it on the foredeck, but it was such a pain to get between the pulpit and the forestay that I got another Delta that lives on the roller, something the Danforth couldn't do.I realise it's not actually relevant to the OP any more, but just wanted to chip in about Delta copies. I picked up an unbranded one from a chandlers a few years back- 16kg for £35. Couldn't resist, and the boat had a 10kg Bruce which I was very keen to upgrade.
Huge mistake. That lump, despite being quite well constructed with thick steel and good welds, was almost totally useless as an anchor. I guess the geometry was all wrong. I could pretty much always drag it when setting, despite having a modest sized engine and a two blade folding prop that gave poor performance in astern.
It's made me write wary of copies, but I guess buying an anchor at virtually scrap price was a bit too good to be true.
Ultra is as good as any, just pricey. I have always felt it to be sufficiently beautiful that its a shame to get it wet. But maybe they are cheaper in Turkey - make sure you buy an original.Thanks again for all the advice. Much appreciated. I'd rather be boating than researching so I'm happy to listen to experts and combine their opinions with my own experience and instinct. Spade it is, if I can find one, and, if not, I may just defy my inner miser and buy an Ultra.
That's a very interesting photo that I had not seen before. Shank strength must be increased dramatically by this measure.Ultra is as good as any, just pricey. I have always felt it to be sufficiently beautiful that its a shame to get it wet. But maybe they are cheaper in Turkey - make sure you buy an original.
On taking care - the original Ultra had a completely hollow shank. It must had had robustness issues and they re-engineered with a web of stainless up the centre of the shank (its welded on both sides). If you see a, cheap, second hand anchor - beware. I don't know when they did the upgrade.
Jonathan
I have spoken to many Ultra owners, most of whom were seasoned yachtsmen with long histories of anchor ownership. I don't think I ever found one who thought it was not the best anchor they had ever owned.
Thank you for taking the trouble. As I said earlier the shank is badly rusted especially around the hole. I actually took it off yesterday and got a guy to weld around it to add some strength. It will do for now for my day sailing but I will definitely replace it before I anchor out overnight again - I'd rather sleep well with lighter pockets than be awake wondering or worrying.I don’t have the dimensions or other details of a spade, but here’s a quick, “back of fag packet” calculation for the strength needed at the hole in the shank where the shackle goes:
I googled your Fountaine Pajot 34 - displacement is 7t
Yield strength of bog standard tensile steel is about 250N/mm^2
If you were to hang your boat vertically, you would need about 275 sqmm of steel (no safety factor). That’s a piece of steel about an inch by half an inch.
So if you measure the width (or thickness) of your shank and multiply it by the depth of it less than the width of the hole, I’m pretty sure you will come up with a figure of at least 275sqmm. I very much doubt you need to be concerned about the shank not being strong enough at the shackle point. The steel used in shanks would be stronger than bog standard and you will never get anyway near 7te being transferred to the anchor - I suspect your cleat/bollard would have long given up.
From memory, never to be relied on, the steel for the shank of a Spade anchor is 'higher' tensile. I don't know that Spade define what steel but think they say it is 'high' tensile.Thank you for taking the trouble. As I said earlier the shank is badly rusted especially around the hole. I actually took it off yesterday and got a guy to weld around it to add some strength. It will do for now for my day sailing but I will definitely replace it before I anchor out overnight again - I'd rather sleep well with lighter pockets than be awake wondering or worrying.
