Deisel tanks
Gordonmc
19 Sep 2001
Loch Riddon for Summer
I am bracing myself for the inevitable replacing the mild steel fuel tanks... but with what?
I could get new ones made up in stainless steel, but as the shape is not irregular, just oblong boxes, this seems an expensive way to go.
There was a suggestion that plastic off-the-shelf tanks have a tendency to split down the seams and could run against some regulation or other.
I want to preserve the plumbing with the feed pipe coming from the bottom and a sump/drain. Do I have to take up from a top opening with a plastic tank?
For info the boat has twin tanks either side of the cockpit. The Port side one is heavily rusted and I suspect there is a good deal of rubbish in the bottom. There will be a fair bit of dismantling to be done, but its all wood.
Any comments welcome.
ccscott49
7 Sep 2001
Vetus plastic tanks, fit and forget, thats what I would use. I would need to fit a bout four of the biggest each side, and pipe them together, but thats exactly what I would do. IMHO
[448]
3 Oct 2001
I'm in the same boat (sic) as you Gordon, and am investigating obtaining 2nd hand tanks from a Mercedes truck. These are some kind of plastic material, and will have stood the test of time, and probably will not be expensive.
Cheers, Dave
stretch33
20 Jan 2002
Essex
Vetus tanks okay although l only had a 24 gallon one. All the fittings went through the inspection type hatch - fuel pick up / return / vent and filler pipe. I was a bit worried about the seal on this hatch but it never leaked. Fuel pick up was about an inch from bottom of tank. Had single baffle in it - it was a bugger to clamp down as l recall, think they supplied webbing type straps that were no good, had to build a timber frame round it.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Re: Diesel tanks
Split plastic tanks are surely a rarity? I understand that many production yachts have them fitted as standard and they are becoming common in the automotive and truck world. I fitted a Vetus one and it was excellent while I still had the boat.
tr7v8
30 Nov 2001
Kent
Re: Diesel tanks
I'll think you'll find that the vast majority of production cars and vans have plastic tanks and have had for around 10-15 years. And you don't hear of many of these splitting. I'd have thought a scout round one of the bigger breakers would find something of about the right size, possibly small van or so and I suspect could be modified with very hot water and a bit of pushing. This would come with pickup gauge etc as well.
Jim
Trevethan
26 Feb 2002
Singapore
Re: Diesel tanks
I tried looking for tanks from vans etc, and the largest I could find in plastic were about 30 gallons each. However someone suiggested tubular aluminium lorry fuel tanks.
Not bought them yet, but this seems to me to be a good solution and will let me carry a couple of hundred gallons without a problem.
Tanks will be under pilot house and far up as possible above the bilge water.
Opinions anyone?
Regards,
Nick
bige
6 Mar 2002
its not worth messing about telephone a company called quay welding in gloucester
they will make any tank any size just give them a plan or your old tank and it will be perfect.just gave them my tank from my saddler 25(steel) and had a stainless steel made £11o and the quality was superb. recently asked for a quote for stanctions in stainless and refering to the pbo article colin (abemama) wrote he paid £1000 for his asked quay for the same price £320 i nearly fell over,unlucky colin?sory i have not got tel no to hand but will post asap
hope this helps bige
bryantee
31 Aug 2001
lefkas Greece (Summer)Cochin india(Winter)
I have a 70 litre vetus tank fitted.Only problem is when the tank top wilts a bit ,the pick up pipe is on the bottom.As there is no bottom drain,filter full of water ,just as we are entering marina.Oh S---.but thats another story.
rectified that by bolting s/s ange across the top plate and have a small filter primer pump with small pipe which fits into the vent outlet .this allows me to take any water out of the bottom of the tank.
