lynallbel
Has anyone mentioned to check/clean the filter mesh?
The smell occurs because the Zeolite absorbs odours from items like cigarettes
Can anybody please tell me if theWasn't me mate. I'm careful not to smoke when fridge raiding
Mine was 240vCan anybody please tell me if the
dd8l uses 12 volts or other sipply internally ? That is, can I hope to run it on a 12v battery without need of an inverter if I get inside and wire to internal supply?
TIA
Thanks for that. Internally the 240v will be converted to a lower voltage d.c. for use of the various components, and if this was 12v dc then I (and we all) could run direct from external battery, bypassing the converter. Unlikely but good if it is so.Mine was 240v
Definitely uses mains voltage for the internal heater element.Can anybody please tell me if the
TIA
And a further question if I may...does anyone know if an inverter would need to be Pure Sine or Modified Sine to operate dd8l safely?Last winter running the dd8L dehumidifier for 8 hrs daily , and sometimes every other day, was sufficient
It does cut in and out , as said .
But even so it would soon munch though the capacity of a battery.
If no shore power is available some other approach is required .
I’ve just been reminded to plug mine back in - the Zambezi model - and it doesn’t smell although it’s prob. Been 6months plus since it was last used. A quick question re the laundry mode though - should there be another heat source to help the drying process as I’m thinking of using a specific cabin just for drying clothes as although I have a washing m/c I don’t have a dryer and I don’t plan on adding one
Well pure is more efficient, so pure.And a further question if I may...does anyone know if an inverter would need to be Pure Sior Modified Sine to operate dd8l safely?
Nope it does all the work itself, just try and keep the room sealed.
We are currently using one to dry clothes on one of them ceiling mounted airers, seems to be working okay if a little slow, but way cheaper than the clothes dryer.
