jrudge
The Defibrillator was acquired through British Heart Foundation with a village project to raise the £400 to purchase it plus cost of suitable cabinet and signage. Our local retired GP carries out regular checks on the equipment.
The key point to note is that use of a defibrillator is only one part of the rescue procedure, with heart massage being the most important. Training is essential.
I guess such equipment would be of limited value on a boat unless there is someone else there to use it when needed. It is obviously not a DIY task!
I think the key this is that they now ARE are DIY job.
The machines are fully automated and THEY decide to shock - NOT the user.
I you look here and follow the Video link
http://heartsine.com/product/p/samaritan-pad-360p/
You will see the instructions.
It then goes on to tell you how to do CPR.
So yes of course knowledge may help, and reduce shock / fear factor but the machines are designed to do their best and tell the user what to do.
Which of course is what they can be deployed in public places.
The stats below seems to vary a bit, but the general message seems to be that with nothing your odds are less than 10% and with a rapid intervention, a shock and CPR this goes put to circa 50%. 70%.
Those seem pretty impressive stats. Almost certain death or an above even chance of coming through.
Henry - I also fully agree with you. I have just dropped 10.5kg and have at least as much to go, so prevention is clearly preferable to cure!
