Just fitting the same thing with a little distribution board down below made up with Wago 2 way connectors superglued to a board. Similar to those shown in the photo of the 12v distribution panel. middle of the photo under the GarminI used this in place of 4 connectors. Easy to add more cables later.
If you need to disconnect the cables you can add inline connectors such as these connectors. either above or below decks. (only the small ones will fit through the swan neck). They are IP68 and with gold plated pins so no corrosion.
I'm just about to get rid of the swan neck that came with the boat, and change to the Cable port type shown above, as the swan neck is prone to snagging the genoa sheet on tacking from starboard to port.I used this in place of 4 connectors. Easy to add more cables later.
Agree that the swan neck is not suitable at the mast where it will get knocked and catch lines. Mine is right aft, behind the lazarette hatch and under the tiller where it is well protected. I have cables for AIS, stern light, autohelm and solar panels at the stern. The mast only has nav lights and VHF so I have stuck with cable glands for these. If I had wind instruments and radar on the mast as well, then the cableport would be a good solutionI'm just about to get rid of the swan neck that came with the boat, and change to the Cable port type shown above, as the swan neck is prone to snagging the genoa sheet on tacking from starboard to port.
Besides being g a PIA to go to the mast to untangle it, I have now discovered that it's seal to the deck has become compromised some time ago, causing water and a soggy patch in the coach-roof, which is going to be an enormous PIA to remediate.
I have a plug/socket of the kind that Refueler has.Some interesting ideas there, thanks. It's not the waterproofing that worries me as much as the loss of connection. I use white grease, thinly, and that seems to keep the pins and sockets dry mostly, but they're brass, and that's not great round seawater. Refueller hits the nail on the head with the differing diameters between pin and socket. After a while the fit is sloppy, and so a poor connection results. I'd not thought of modifying by cutting the pin, but some plugs have that idea already, to keep the pin tight in the socket. Moving the sockets inside is an idea too, through one of those cable housings. So, I have until next spring to figure out the best solution!
FlatGland.I've always used the so called AAA type. But I've always had problems. They don't leak a lot, but the pins (on the plugs) corrode and the sockets too, and they then loose connections, so losing instruments, or lights or whatever they connect.
What is a suggested better type for boat deck use?
View attachment 143487View attachment 143487
A smear of Contralube works for meSome interesting ideas there, thanks. It's not the waterproofing that worries me as much as the loss of connection. I use white grease, thinly, and that seems to keep the pins and sockets dry mostly, but they're brass, and that's not great round seawater. Refueller hits the nail on the head with the differing diameters between pin and socket. After a while the fit is sloppy, and so a poor connection results. I'd not thought of modifying by cutting the pin, but some plugs have that idea already, to keep the pin tight in the socket. Moving the sockets inside is an idea too, through one of those cable housings. So, I have until next spring to figure out the best solution!
