vyv_cox
It is not anodised - just primed and painted.
Is that so? In view of the many reported problems with saildrives I would have expected them to be anodised at the very least.
I had a similar saildrive corrosion problem last year. Again the anode was not eroded at all but much of the paint had come off the saildrive leg and there was erosion of the metal around the drain plug. Fortunately not as severe as your photos appear to be. I put the problem down to no electrical contact between the anode and the saildrive, which relies on bare metal-to-metal contact at the small bushes around the mounting bolts. This was found using a multi-meter - I also checked isolation from the engine and prop, which were both OK.
The saildrive needed extensive surface treatment and re-painting. I also added a dangling anode connected ONLY to the saildrive by routing a wire from the top of it's gearbox, out through a deck locker to an eye-bolt where the anode cable gets clipped (the cable is covered in a piece of garden hose to stop it earthing onto the stanchions where it goes overboard). We've just lifted out after a season afloat and I am pleased to say that it still looks good. Much more anode erosion this time.
Corrosion treatment went like this:
1. Abrade away all of the affected areas where white oxide powder has formed until you have solid metal everywhere.
2. Neutralise the aluminium surface with Deoxidine 624 phosphoric acid etch (I bought it from Light Aero Spares in Devon)
3. Etch prime with PR30B (or similar DTD 900/6064) also from LAS.
4. Epoxy build filler to fair the surface if necessary.
5. Marine 2-part epoxy prime, 2 coats.
6. Antifoul Trilux 33 or similar.
As previously posted, unless the leg is severely structurally weakened or seeping oil then it should be repairable.
Is cost the only reason saildrives aren't made out of some sensible material like bronze, composite, steel, etc, instead of melt before your eyes die cast aluminum?
