LostinFrance
Not the best of sights to see on a Saturday morning, especially when it's your own boat. I've always been so scrupulous in replacing the anode every year and I can't understand why the saildrive is so buggered when the anode looks like it could be used for next year too!
Apart from the cost of replacement I'm trying to understand the reasons here; if anyone has some input of the useful kind I'd really appreciate it.
The boat was put back into the water late last year in June, the only thing I did differently to every other year is change the drain screw on the bottom. There was no apparent damage at this time anywhere.
It spent all year until now in the water, only occasionally on mains electricity.
I fitted a solar panel last year - possible problem?
I fitted a Galvanic Isolator to the mains inlet five years ago.
I did wonder if there was damaged caused when the sling from the crane wasn't removed from the water and, not noticing this, I wrapped the prop with it. I was wondering if it put strain around the bearing housing (where the metal is eaten) and cracked the alloy, making it easier to be attacked, but the area around the drain screw is also badly eaten.
The boat spent it's last two years in Holland, I don't know if this problem is more prevalent there. Unfortunately the boat is still in Holland, so it's not exactly next door to me to investigate further and I thought I'd better leave it all untouched in the (99.9% forlorn, I know) hope that the insurers might cough up.
Anyone know where I can get second hand S130's?
