Praxinoscope
The 290 is a newer design but I think i still prefer the 29Thank you - even the Sadler 29 is newer design rather than the 290?
Agree with the older designs. However, the Bill Dixon designs were more modern design, comfortable and performed reasonably well. The reason I suggested the 31S was the better performance over the 31.To be honest, it was the Moody I was referring to as a bit of a tub. Perhaps it’s the dated deck styling, but I just can’t get past it..
The 290 is much under valued, accommodation and performance unfortunately probably above budget.Thank you - even the Sadler 29 is newer design rather than the 290?
The Moody S31 ? Moody S31 archive details - Yachtsnet Ltd. online UK yacht brokers - yacht brokerage and boat salesAgree with the older designs. However, the Bill Dixon designs were more modern design, comfortable and performed reasonably well. The reason I suggested the 31S was the better performance over the 31.
Then you want a 2000-2007 Hanse 31series. Apart from the self tacking jib, making SH sailing a doddle; the stbd berth in the saloon can have a pipecot side & be used to anchor a cot.the child can be placed here when the boat is under way so can easily be seen from the cockpit & attended to as required.Thank you - this is really helpful. Saloon size (and ability to cordon off sleeping baby while we sink a bottle of wine) is one of my major factors.
I’ve been on a couple of 290s. I thought they were a very clever design, and the accommodation much better than say the Westerly Merlin whose saloon narrows excessively. Although twin keel, I can believe what people say when they say they sail well, although I imagine on the livelier side than the 29. The one thing that would put me off on the 290, if it can’t be corrected, is the mainsheet following the fashionable course along the coachroof and not to the helmsman’s hands. My 29 was fin keeled, and as with all the Sadlers other than the 290, had far better performance than the bilge keel version.The 290 is much under valued, accommodation and performance unfortunately probably above budget.
Beat me to it. A bit smaller, classic lines, row away factor. Bit of wood about it but not too much. How do they sail though, fast enough for an ex-racer? I've only admired from afar.The answer to all "What boat should I buy" questions is:
A TWISTER!
This leaves a clear path fore & aft on the other side of the table where child can be seen but not disturbed. Alternatively, there is the forward or aft cabins, with lots of room for mum to sleep with child when needed. Or leave child in one & shut the door whilst adults are in other, leaving 4 more berths. 2 in the saloon & 2 aft or forward
But best of all, is the really large heads, with good shower area. Excellent for washing the inevitable nappy s..t & vomit, off one's self that will always happen. Especially in a boat environment. The shower unit gives a good spray & a child washing can be done whilst sitting on the lid of the loo with the sink alongside. Lots of space infront as well. The calorifier is big enough for an adult to shower so ample for a child. If a cockpit tent was to be installed & tiller steering instead of a wheel the area would be a good sheltered area for a child growing up. The later 315 has a walk through transom but it can be
They are gorg but the accommodation…Victoria 30
All completely brilliant considerations, thanks. I presume you have one for sale?Then you want a 2000-2007 Hanse 31series. Apart from the self tacking jib, making SH sailing a doddle; the stbd berth in the saloon can have a pipecot side & be used to anchor a cot.the child can be placed here when the boat is under way so can easily be seen from the cockpit & attended to as required.
But best of all, is the really large heads, with good shower area. Excellent for washing the inevitable nappy s..t & vomit, off one's self that will always happen. Especially in a boat environment. The shower unit gives a good spray & a child washing can be done whilst sitting on the lid of the loo with the sink alongside. Lots of space infront as well. The calorifier is big enough for an adult to shower so ample for a child. If a cockpit tent was to be installed & tiller steering instead of a wheel the area would be a good sheltered area for a child growing up. The later 315 has a walk through transom but it can be closed off with solid door
Storage is not bad throughout & a carry cot/push chair can be easily stored in the locker accessible from the rear of the heads compartment or above deck
They’re lovely. But very much like being entombed down below. You sit right down in the hull so it’s very dark…Beat me to it. A bit smaller, classic lines, row away factor. Bit of wood about it but not too much. How do they sail though, fast enough for an ex-racer? I've only admired from afar.
I suspect my friend William, will along any minute now to put you right back in your box about the E333 slamming. Quality of Build etc, etc, blah Blah Blah....He loved his. but I do suspect you are talking out of your A%&!OK, I will open the discussion and put my tin hat one.
Sadler 32, 34 or Starlight 35? all OK if within budget. Contessa, classic drool over lines but wet and cramped with a small baby-but very seakindly.
Channel 31, good reports but no experience.
Elan 333, I will now put my chin strap on my tin hat! Modern design, flat bottomed and slams a lot, quality of accommodation build is mediocre, edging towards lightweight rather than longevity.
Suggestions within budget, 90's British built, Westerly Fulmar, Moody 31s, others you've mentioned or, I understand early 90's Bavarias were well build with a rounded bilge to reduce slamming and good long lasting boats.
Cosy! Snug!! Classic lines you saidThey’re lovely. But very much like being entombed down below. You sit right down in the hull so it’s very dark…
They sail superbly, especially to windwardBeat me to it. A bit smaller, classic lines, row away factor. Bit of wood about it but not too much. How do they sail though, fast enough for an ex-racer? I've only admired from afar.
I would not take small kids sailing in ANY yacht. Leave em at home with the grandparents. That is what they are forThey are gorg but the accommodation…
He’s absolutely committed and loves sailing - he’s just very new to it.I would suggest that you turn this around and think first about how you can get the other half to join you on board with the baby.
If he doesn't like sailing and wants comfort first then look for that first.
Get him involved from the start and you will be less likely to be sailing on your own.
