Quandary
I am considering modifying a boat cradle to make it more transportable. The longest (rear) cross frame is a rectangle 3.5 x0.6m. of 80x80x 3mm RHS and the idea is to cut both the long sections and insert internal sleeves of 70x 70 when reassembling. The cuts woulld be staggered so that each half would have a section about 2.1m max length. The inserts would be secured with bolts through the walls.
If I buy a good quality 125mm diamond cutting blade (recommendations sought) for my small angle grinder should it cope with that?
I also have a 9" Makita used for cutting paving slabs etc. more powerful but quite heavy and unweildy.
