nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
Further to this ...
I've been considering ways to cut such a bevel around the removed through-hull. From the outside it is easy, but on the inside I have very little space around the hole. My latest idea is to use a powered sander, with a modified disc and pad.
The required bevel extends 100mm around the 25mm hole, so 225mm diameter. I can modify a backing pad so it has a conical shape with a 225mm base, then re-apply the hook backing. If I then cut a segment out of a 250mm sanding disc, I could apply this to the pad, with an overlap in the right direction. I think 60G is the lowest grit I can get in this size.
Thoughts?
I recently contacted Gougeon Brothers (West System) as follows:
I have read your document at http://www.westsystem.com/ss/repairing-machined-holes-in-fiberglass/ I have a 1" drilled hole at the bottom of my hull, currently occupied by an unused 3/4" through-hull (skin fitting). The GRP is about 1" thick at this point, cutting a 12:1 taper will result in a huge area. Please can you advise the best solution.
Reply:
Ideally, you would grind a bevel from both sides - in and out. This allows you to reduce the bevel to 8:1 so the effective thickness of the laminate becomes 1/2" making the bevel 4" from the edge of the hole on both sides. I wouldn't recommend you go any less on the bevel since this area is a high risk area where failure could be catastrophic.
Bruce Niederer | Senior Tech Advisor
Gougeon Brothers, Inc
Thoughts?
