Neil_Y
How much does the prop overhang the cutlass? I believe a rule of thumb is something like 3x shaft diameter. If you have more than this it can cause vibration and premature wear. Hope this helps.
More like half shaft diameter to shaft diameter, we aim for 12.00mm as ideal for a soft mounted drive train. This allows for a max of 9.00mm forward movement leaving 3 mm for water to exit the bearing. In practice only a few boats see this much shaft movement.
