CTS across tidal water with B&G
Oodles
28 Feb 2023
Hi,
Does anyone know if it’s possible to get a B&G Zeus 3 to calculate a course to steer across tidal waters? At the moment I can do this manually on paper by adding the tidal vectors for the passage using assumptions of speed. Using the Zeus I can get it to provide a rhumb line but that’s not at all ideal. What I’d like is to see the (for example) classic S shape on the chart and to be able to follow that to get the quickest route.
Many thanks
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
Hi,
Many thanks
If you STEER the rhumb line, your course over the ground will follow the S-shaped pattern you describe - there's no need to steer it, it just happens! There are programs that will provide tide corrections - SavvyNavvy comes to mind, and I think some modern chartplotters provide that function.
James_Calvert
6 Oct 2001
It would be clever though, to have the plotter project the S curve as the intended track, and measure the cross track error from that.
Wouldn't it?
AntarcticPilot
4 May 2007
Cambridge, UK
Wouldn't it?
I suppose that doing that would mean that the autopilot wouldn't be attempting to steer back to the rhumb line, resulting in an inefficient course. But I guess that I'd be concerned that tidal atlases don't tell the whole story; there are often local back-eddies that the broad brush of tidal atlases don't capture. Averaging things over the whole track is going to work better than the piece-wise corrections that would be needed to work out the actual track over the ground. In principle I think it's a good idea, but I wonder how practical it is.
When I'm using the autopilot for a long passage, I tend to set it to a bearing, not to a track.
