CT1 in Greece - Lefkas area?
I need Some CT1 adhesive/ sealant - Is it available in Greece, particularly Lefkas, Nidri, Preveza area ? If so what brand/ name is it under?
TURBO-Fix 98445 I installed with this glue all thru hulls without any problems about 4 years ago. There is also sikaflex that does but I would only use it for gluing to the keel. You can find them in Lefkada
Proloc is widely available in the area. Ionion marine chandlery at Aktio definitely stocks their products - 242 is their general purpose marine adhesive sealant: PROLOC MARINE LINE - ADHESIVES & SEALANTS
They also stock Sikaflex 291 as Brits abroad have quite the fetish for it, but if it's used anywhere exposed to the sun, you're much better off with the Proloc 242.
The CT 1 is actually for helping secure headlining , on the back of non adhesive Velcro , as all other adhesives seem to have ‘melted’ in the heat of the Med including those with a good temperature range. It was suggested I try CT1 , which I was going to test on a small area
