l'escargot
Good luck.
Thank you. But as you know, I don't need luck when complying with the regulations - as opposed to your interpretation of the regulations...
Good luck.
My crew. Or me if single handed, or they are novices.Who does the tying up?
Why ever not?3g is not a primary source of weather forecasts, compared to radio and navtex,
Its not an interpretation. Its SOLAS chapter 5. Safety of Navigation. Worth a look.
Just don't cock up and you will be fine.
I'm getting really confused now. I've just read SOLAS chapter 5 (twice) and can find nowhere mentioned that a written passage(voyage) plan is required. What am I missing?
But it doesn't say that I need to WRITE DOWN, IN WRITING my passage plan surely? I thought I just needed to MAKE A PLAN which could be me thinking, it's a nice day, I'm going to jump in the boat, and float about for a while.
It doesn't work at sea!
You may have missed regulation 34 and annexe 23. Be aware that a passage plan need not be written but bear in mind (as I said before) how you will prove your plan if it all goes breasts up.
Interesting question. If you write a plan down and it all goes wrong, are you in trouble for making a bad plan?
Neither does Navtex if you are far enough out. 3G is a perfectly acceptable method of getting weather for the vast majority of "passages" in coastal waters.
I'm glad 3g works for you, my reception fails while still in sight of land. (E which used to be T mobile).
I only need signal once every 6 hours since that's how often the forecasts are updated.
Primarily, i dont plan at sea. And it does if work at sea if you have decent comms anyway, it is way better than navtex or radio as you have diversity of information.It doesn't work at sea!
