vas
go Robin go!
although I agree with most posters, I think there's always a fine line between all the compromises (in originality, looks, usability, safety, etc)
If it was one of 100fletchers ever built and one of the 10 still alive, I'd say possibly don't do it.
Since I doubt it's that sort of numbers we are talking about, I'd just do it!
However a horizontal windlass will look (at beast) odd, obscure, out of place, too large on your craft.
SpiD photos is what you should try to achieve.
Namely vertical windlass (assuming you do find one with a solenoid to release the anchor lock), cut on the bow, create a flip cover and a second floor for the chain, waters, windlass.
If you could post a section with the waterline in place, one could easily (?) figure out what fits and how. The bulkhead and windlass will mount way aft (possibly way more than you'd expect!)
The main problem is that you need some depth (to mount the windlass without it poking way above the bow) to store the chain warp underneath AND you still need all that to be someway above the waterline to be able to dump water/mud/etc out from the to be built drain... If you end up with a locker that you can only fit 20m of warp in it, don't bother...
cheers
V.
cheers
V.
