rbcoomer
Hi,
As some of you will be aware, I'm restoring a late 70's Fletcher Arrowbolt GTS (21'6"). The vessel currently has no form of anchor locker, but as I've stripped back to bare hull I have a blank canvas and there is room. Unlike later variations, the screen is also continuous with no opening centre section and no walk around space to get onto foredeck - thus the only options are to climb over the screen or via the cuddy through the hatch. The cuddy is really just a kids space or sleeping 'tent' as there isn't enough headroom for an adult to sit comfortably, so climbing through if running solo to deploy/recover anchor doesn't seem ideal!
To make life much easier, especially when single handed, I'd like to fit a windlass and a bow roller and wire back to the helm for anchoring. I think I need a 'horizontal' windlass due to the 'pointedness' (for lack of a better term!) of the bow and lack of depth...
I've no idea what power is required however for a 6M boat? The deepest we are likely to anchor would be 30M and that would be the exception rather than rule, so probably 10M chain (8mm?) and 40M of warp needs to fit in the locker. I think this is easily do-able as although the highest point would only be around 40cm, I have a reasonable fore-aft length to work with. (I'll measure later and get some pictures when it dries up a bit!)
Budget is fairly constrained, but I've seen 800W units for around the £600 mark new (e.g. Quick: http://www.quicknauticalequipment.com/?lng=en&cs1=01&ms1=2&ms2=1&ctm=205 ) and I'm also not averse to buying second hand either. Something with an automatic free-fall seems like a good idea as quick deployment in the event of mechanical issues etc without having to climb to the bow would be a big plus! Although I'm not quite ready for the windlass yet, I need to cut and form the anchor locker in the next couple of months, so any thoughts, experiences or advice gratefully received!
Cheers,
Robin
Cheers,
Robin
