fisherman
This survey is solely because the boat became unregistered and has to register as if it were a new vessel. Once only, but insurance companies insist on any certification being up to scratch so he is loath to alter it afterwards. The bulkhead is not designed to stop free surface effect, that is dealt with much better by getting the water below where there are subdivisions already, it is in case the hull is breached. Clearly such a small, 4.88m boat flooded either side of a midship bulkhead up to 200mm below the gunnel top is going down by whichever end the water is, whereas if the water is below deck and evenly distributed it will settle evenly and there is more chance of pumping out. I showed him some two pot foam today, and suggested he seal the deck except for a central sump end to end, filling the voids with foam. He would have to consult the surveyor, and pay for the privilege, (the initial survey was £650, my last survey was £350 on my 32ft) and there would probably have to be calculations. AND, with underdeck space drastically reduced water would soon overtop the deck and become free surface effect.......I have offered to pen a complaint to a higher authority, but he is scared stiff of upsetting anyone and making things worse. The surveyor is someone who 'used to work as a boatbuilder', I would like to see his quals.
We get the feeling they just want us out of the way.
