Neil
I have my little Sadler 25 out on the hard and in a Tennemast cradle for the first time since I bought the boat. Each year, I've slapped on more antifoul such that the surface resembled a lunar landscape with lumps coming off with a new application. So I bit the bullet and have scraped off the thick of it.
It occurred to me that with a little more effort (and cash) the surface preparation would be conducive to Coppercoat.
When the boat was lifted out, the day was supervised by the lift out guru. He checked every cradle and made adjustments before each boat was lowered. Currently, my pads are below the waterline. This would require me to substitute a temporary prop for each pad in turn, for both scraping, polishing and Coppercoating. Clearly this will be a PITA. Ideally, I'd like to do it all in one go which would require the pads to be placed above the water line.
Now, the entire weight of the boat is on the keel, and when it was set down, wooden chocks were placed such that the keel was supported evenly. The pads, therefore, are just there to stop the boat falling over. I can't think of a reason why I can't substitute a temporary prop while raising each pad support in turn so that all are above the waterline. What is wrong with my logic? Certainly, all the boats around me have their pads below the waterline.......
