D
Deleted User YDKXO
Guest
Mike, have you pulled the interior trim off round the windows to see if there's some component that's touching the edge glass at the location of the root of the crack? And to what degree has the apparently-degraded bonding failed - is there a gap or unadhered patch where you can slide some fine tool through?
No I haven't Jimmy. The window is sealed with Sikaflex both sides and on the inside there is a trim piece which is either sealed or glued in place and which I could make a real mess removing. It would be easier to remove the Sikaflex from the outside and poke around but I can't do that until the boat is lifted in March
