Kristal
Having brought all Crystal's spars home to London for stripping, sanding and varnishing, I've found something rather irksome.
There has been some kind of reinforcement at the aft end of her bumkin to allow the fitting which connects it to its stay, and the mizzensheet to the bumkin - is this still called a cranse iron? - to be replaced with one of a larger diameter. This appears to have been done with some kind of glassfibre, a material about which I know very little. In places, the glassfibre has been allowed to spill over a little onto bits of the spar which are not covered by the fitting when in place, as can be seen in this illustration (Fig.2):
Ignore the blackness, that's just where the varnish has failed (presumably from reflected sunlight, as this is the underside when the spar is in situ) - much of the wood was this colour when the varnish was removed, teaching me a lesson about varnishing and giving me a sore arm! The spillover is the light-coloured bit, where it has been caught by the sun when I took the photo.
IMO, it looks pretty rough, although admittedly I never really noticed it when the bumkin was in place.
The photo shows the worst example, but it has happened all around the diameter of the spar. While I'm doing the job, I wondered if there was any way to disguise this. I am considering painting a black band around the end of the bumkin, and painting the fibreglass (if that's what it is) and the very end of the spar black too, and varnishing over everything not covered by the fitting. I thought it might be a nice contrast with the wood.
As always, I'd like some opinions on this, or any other bright ideas. It does seem a little pernickety, but seeing as I have committed Crystal to a whole year of maintenance, I figure now is the time to deal with little imperfections like this.
Thanks in advance for your thoughts!
