Could be boaty ... need sheet wood but not plywood
JumbleDuck
8 Aug 2013
SW Scotland
For a work project I need to get hold of some thin flat wood which isn't plywood. In an ideal world it would be 5mm thick and a metre square, but this may be too much to ask, and anything down to 30cm square would be fine.
Any bright ideas?
Poignard
23 Jul 2005
South London
Any bright ideas?
6mm MDF?
(Veneered if it's going to be seen)
sarabande
6 May 2005
providing that wood to those dimensions is going to be very expensive in newly-sawn / prepared timber.
The best suggestion I can make is to peruse the old wardrobes and cupboards in 2nd hand furniture dealers. Old and unfashionable furniture often has large pieces of solid wood at the back.
bedouin
Any bright ideas?
Must it be a single sheet?
The only wood I can think of for that would be Balsa wood - but not sure if you can get it in that sort of size.
JumbleDuck
8 Aug 2013
SW Scotland
Thanks, all. Must be wood, so MDF and plastic out, and can't be balsa, alas. Could be thinner, though, if anyone knows a good source of non-decorative veneer.
parbuckle
7 Feb 2011
Boards of 5mm have very little structural strength so before the advent of plywood anything of this gauge would be fixed in a frame as support so as previously mentioned I would look for old panel work.
alahol2
22 Apr 2004
Portchester, Solent
www.troppo.co.uk
prv
29 Nov 2009
Southampton
Trees don't come in thin sheets, so sawn timber (as opposed to engineered board) generally doesn't either. If you do find a short length of a very wide plank, it won't be as stiff and stable as you may expect from plywood.
D
Deleted member 36384
Lanarkshire Hardwoods have some massive logs and the machinery to cut them. Google and call the guy he may be able help. Perhaps a thin ring which a 1m x 1m x 5mm section could be cut out, can be sawn from a log, tricky I would imagine. The old wardrobe idea sounds good.
PetiteFleur
29 Feb 2008
Suffolk
Old wardrobes are a good idea - I've just broken up a wardrobe and ended with a pine back, 2 pine inner sides and two mahogany sides, all about 20" wide and 5' long x 15/19mm thick. Very useful and nicely seasoned.
