Designo
and yet another year later, another related Q
I guess since I'm the OP I don't have to apologize to anyone, just trying to keep relevant threads together for future reference.
So, I'm about to slice the pieces of teak Ι bought last year!
My first attempt at gluing teak will be at the small pieces of flooring for the heads. They are removable so will be done in controlled conditions at Georges' workshop and probably pressed in his large press that he uses for doors and such.
Q: do I slice the teak beams (50X180X2000) at 6 or 7 or 8mm thick?
I'll try and source the glue that you recommended (last time I tried to find it was import from the States though...) and obviously sand it afterwards for a uniform thickness feel with one of these special sanding angle grinder things (what around 300mm in dia and featuring a lip all around to keep the thing flat)
I'd be tempted to go for 7 so that I have at least a decade to do a few sandings before it disappears, but would be happy with 6mm if its considered enough for two-three sandings.
cheers
V.
The thicker you have, the longer it will last. Not mainly because you can sand it more times, but it will not dry out and disintegrate...
