coppercoat?
silverdawn
30 Jan 2005
mountnessing essex
Hi All, I have just finished ( 20 hours) manually scraping the many layers of antifoul from my 28ft boat, not a process i would ever repeat, the question now after all that hard work
is... do I prime and re antifoul £120 or do I coppercoat £ 560.? if i expect to keep the boat
4/5 years money wise I break even, plus no annual antifouling, but due to unforseen circumstances if I need to sell in 2 years I would lose money, I know the amount of money loss is small but so is my disposable income (pension),and there are always other things to buy or maintain.
However would having a coppercoat boat be a good selling point,I think it would what do you think? I would welcome your thoughts.
I would still have the boat lifted out each year so no money saved on that .
Gwylan
31 May 2007
Moved ashore
Go for the CopperCoat - we did it in 2006 and do not regret it. Quite a felling of quiet superiority as you bring the boat out and just give it a pressure wash and go home. Also have a sense of environmental superiority - not using anti foul or having to clear up.
As you get older the scrubbing and painting gets harder not easier.
Prepare well, have a dry not too hot day and some chums to mix and get the stuff correctly and roller it on in a reasonable time
Canopy Locked
5 Dec 2006
Nth East Scotland
Agree... had copper on my last boat and was excellent. Currently getting the old a/f off mine (very slow), because there are a few minor repairs to do to the hull. Once rubbed down and ready I plan 2 coats of epoxy and 4 coats of epoxy copercoat. Should be job sorted for many years to come.
Sans Bateau
19 Jan 2004
Another vote for Coppercoat, but to ensure a successful application, good preparation is essential. Application is best tackled by two of you.
silverdawn
30 Jan 2005
mountnessing essex
coppercoat.
Hi, thanks for the replies, so far unanimous for coppercoat which from my research is not surprising, but to confirm coppercoat is an epoxy resin which copper powder is mixed into and applied to a clean and abraded hull so why would would you put two coats of epoxy then four coats of coppercoat ? four coats is the recommended covering using the copppercoat, what is gained by applying the two epoxy base coats other than the obvious
answer four coats are better than six! but are you actually gaining more protection surely the coppercoat on its own is enough protection.
Just checking in case I have misunderstood the concept or perhaps the six coats are a personal belt and braces job which gives peace of mind. ( regards stuart )
Sans Bateau
19 Jan 2004
We applied 2 coats of epoxy then 4 coats of Coppercoat, but only because the hull was very dry (according to the surveyors readings). The Coppercoat epoxy is, I understand, not a barrier, it gradually erodes to expose more copper. This was told to me by someone from Coppercoat.
silverdawn
30 Jan 2005
mountnessing essex
coppercoat
Hi galadriel, thanks for the above information I thought coppercoat was a barrier plus an erroding antifoul all in one, if not then it makes sense to apply an epoxy barrier especially
after all the hard work getting to the gel coat!
Sans Bateau
19 Jan 2004
Search out an epoxy coating called ME100, much cheaper than 'branded' products and I understand the same as one of the expensive retail products.
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
Coppercoat is great stuff but absolutely not a barrier coat. I believe AMC (the Coppercoat company) used to claim that it had some barrier effect, but no longer do so. The Coppercoat epoxy is strange stuff: 50% water. It dries as well as cures.
2 coats of epoxy before the Coppercoat puzzles me. If it's simply a a primer, then surely one will do; if a barrier coat, 2 is too few. The general view is that 500 microns (0.5mm) should be applied. Depending on viscosity, that means 3 to 5 coats.
26 Nov 2009
everywhere
No, the coppercoat alone is some protection but not really enough. After all, the copper in the coat has to be available to the water in order to work so that suggests that the coppercoat alone isnt sufficiently waterproof to prevent pox.
I have coppercoat. I wouldnt suggest its quite as effective as antifoul but then thats rather top be expected since antifoul contains both copper and biocides. But its worth it for the labour saving alone.
As for re-sale price, how would you ever know? For identical boats, the spread of achieved selling prices would likely be much more than the cost of copper coat - you could even find a boat with antifoul selling for more than one with copper coat. Just look at the price spread for identical items on ebay to see what I mean. So just look at the question in terms of its value to you.
dslittle
7 Jun 2010
On our way
Thumbs Up for Coppercoat
Got mine Coppercoated in 2009 and lifted out in Nov 2010. Quick pressure wash and looked as good as when it went in (I did post some photos of the lift out back in Nov) As you, I still intend to lift annually (as prices go up that might change) but absolutely happy with the Coppercoat. If you work out what 20 hours x 10 years (their predicted lifetime) is worth to you, it is a no brainer for me.
In relation to resale, I would definitely go for a boat with Coppercoat at the same or slightly greater price as a result of my experience so I think it would be a good selling point personally.
youen
3 Jan 2005
Brittany
coppercoat
How dirty was your boat when you get it out of the water.Because on mine who is also copper coated I need to get her out of the water 3 times a year.After 3 months she become dirty with slime particulary near the waterline and the rudder.Before with conventional self eroding antifouling the hull was kept clean during 6 months
Talbot
23 Aug 2003
Brighton, UK
Coppercoat seems to be gaining a reasonable reputation for northern waters, but less so for warmer climes. I wonder if a combination of ultrasonic and coppercoat would be the real answer for long distance cruising.
macd
25 Jan 2004
Coppercoat seems popular with UK liveaboards in the Med, and all I've spoken with believe it works well. Galicia, mentioned by youen, is reputedly a particularly high-fouling area, although I've no long-term experience of it myself.
dslittle
7 Jun 2010
On our way
A year in the water
Keel coming out after 13 months on the South Coast. The bottom of the keel was not Coppercoated...
silverdawn
30 Jan 2005
mountnessing essex
coppercoat
Thanks for all the replies,very informative plus not a negative report with regard to coppercoats performance.I have come across a one coat copper antifoul system manufactured in germany very effective according to the web page verometalmarine.com.
I have e-mailed them for more infomation plus cost/postage etc.I dont think this one coat system can match coppercoat but it could be a compromise for me due to reduced cost.
I will update when I receive the information.
3 Jan 2011
South East
www.maplemarine.com
I would echo the need for good preparation prior to application.
I have seen boats with large blisters in the coppercoat layer where it has not stuck to the original gelcoat where preparation was not up to scratch.
