G12
Maybe Gelshield (or equivalent) before the Coppercoat would be a good idea.
Thanks for all the replies,very informative plus not a negative report with regard to coppercoats performance.I have come across a one coat copper antifoul system manufactured in germany very effective according to the web page verometalmarine.com.
I have e-mailed them for more infomation plus cost/postage etc.I dont think this one coat system can match coppercoat but it could be a compromise for me due to reduced cost.
I will update when I receive the information.
If it is a "one coat" application, it must be snake oil.Hi all , received e-mail today regarding the german copper antifoul Verometal M 300 I was looking for a alternative to coppercoat as this was to expensive £ 560 for my 28ft bilge keel yacht ,M300 is a one coat system which they say lasts for minimum 10 years so in this respect is the same as coppercoat the M300 comes in 2.25 Kg packs @ £150.00 per pack inc postage, for my boat I would require 4 packs =£ 600.00 so the price is almost the same
but still beyond my buget.However if it does what it claims with one coat then it could be an alternative considering all the time and labour involved applying the recommended 4 coats of coppercoat.Regarding my boat I have decide to apply 3 coats of Jotuns penguard HB epoxy primer to the prepared hull plus 2 coat of Jotuns Seaqueen antifoul. many thanks for all your advice and comments.
I'm inclined to agree.
By the way, there is no such thing as 'coppercoat'. Check your dictionary. 'Coppercoat' (with cap 'C') retains a sound reputation after many years during which most of the pretenders have come and gone. I wonder why.
Emphatically not related to Coppercoat as anything but a customer.
Iam Disappointed you feel the need to point out my punctuation errors in such a sarcastic way
coppercoat it worked well until we first jet washed it off...it didn't work at all after that!
Apologies for any offence caused. My intention was not to have a dig at your punctuation. As you rightly suggest, the message is more important than the means. My point was that 'coppercoat', 'copperbot' and 'copper-pretty-much-anything-else' are often bandied about on these forums as interchangeable generics when they are not. When referring to specific products, it's helpful to be unambiguous.
They still claim it is a barrier against Osmosis. In their How It Works Section they state "Furthermore, the inherent waterproofing qualities of the epoxy ensure that a treatment of Coppercoat will help prevent osmosis in GRP craft and offer extra protection against corrosion in steel vessels.Coppercoat is great stuff but absolutely not a barrier coat. I believe AMC (the Coppercoat company) used to claim that it had some barrier effect, but no longer do so. The Coppercoat epoxy is strange stuff: 50% water. It dries as well as cures.
2 coats of epoxy before the Coppercoat puzzles me. If it's simply a a primer, then surely one will do; if a barrier coat, 2 is too few. The general view is that 500 microns (0.5mm) should be applied. Depending on viscosity, that means 3 to 5 coats.
Could you clarify: did you mean you jet-washed the Coppercoat or jet-washed OFF the Coppercoat?
no it didn't remove the coppercoat but i think it may have dislodged or helped to remove the oxidised copper needing a new layer of copper to be exposed by abrading the epoxy, the epoxy should eroded by itself but after the yet washing we were left with too much epoxy and not enough copper!
CopperCoat, used by 100's well known, tried and tested.
Verometal M 300 Never heard of it, let someone else be the pioneer!
In the 5 years we have had CopperCoat on Galadriel, we have never abraded, but have jet washed at least once a year. This winter the boat is ashore, so abrading will be done just prior to relaunch.
