Elessar
For what You May Care:
I applied CC in summer 2006 to my 40 footer underside. Done on a one month old boat.
Unfortunatly since then my sailing habits had to change (NOT as a result of CC application), and the boat stays moored for more than 6 months in a clean water/nutriment rich marina.
Results? A coat of sand/slime and other INORGANIC material deposits on the hull (no treatment would inhibit this), onto which some small algae and then mussels grow; a few barnacles can find their way, too.
BUT I just lift the boat around 9 am, while the boys at the yard clean the hull with the water pressure jet, I change the zincs, grease the propeller and, presto, by 11.00 she is in the water again.
Next spring I'll give it a run with the fine sander and seee if it goes to the 10 year life span.
Satisfied? Yes. Why? Saved a lot of planning and coordination to have the hull job done. Saved some euros of paint? Probably, but that would not be the main issue in suggesting the product.
Of course, no affiliation whatsoever with CC or any distributor.
Glad you're happy.
As ken suggests though, don't abrade for the sake of it.
You might need to after 6 or 7 years (or more) but only if the perfomance drops off, otherwise if it ain't broke etc.
One bloke at the show said he abraded his every year and evetually wore through it. Even that took 13 years though........
