MapisM
Sod the a/f, THAT is bad. Hope you fully recovered since then!I spent most of last year in & out of hospital, boat unused
Puts things into perspective. Very best wishes for a full recovery, and many happy trips on your new boat.In again now, going home tomorrow, hopefully to recover & that will be the end of it. Been an interesting year, & very scary for family at times.
i totally don't understand. I've never thought mine "unkind". When I say "soft", it doesn't rub off on people.
How can you save a lot? We both jet wash each year and I put a coat on every second year but didn't have the upfront cost of cc. Also mine keeps the bottom clean, unlike cc, so saves a bit of fuel.
Ditto - hope you have a good recovery rubber duck.In the early days, I had a really bad experience with Micron 66.
It went all flakey but if you tried to scrape it off, the oils in the AF stuck the flakey bits back to the hull.
The result was that it couldn't be removed or recoated without sandblasting/soda blasting.
When I complained, the guy at International said, "is this the boat in Palma".
I said "no but it seems you have a problem other than mine".
The situation got worse when International took over the situation and applied Primacon over the top of the congealed mess left by the Micron 66.
During the season before this, the M66 had worked well but we were getting lots of AF being rubbed off on swimmers.
We ran with M77 over the Primacon mess for a season and, yes, it was a bit better on swimmers but not perfect.
So, with a complete mess on the bottom of a 2 year old boat, I decided to remove the lot.
It was then a "no brainer" to apply CC.
I don't regret my decision but I appreciate that I have had bad experiences with the Micron xx products.
I used it once several years ago. Was pretty good- best product I have used. But ridiculously expensive in Côte d'Azur so I have never bothered since. A diver is cheaper!On the same theme, anyone use propspeed ? Any good ?
Thanks for fulfilling my desire!I for one would be interested in some pics of those fine bits of engineering in Boatbore boat.
