thinwater
Without question, a dry suit is the safe answer (a wetsuit in merely cool water). But above about 10-15C air temperature, depending on whether it's raining and depending on activity level, they get a little steamy. In spring weather conditions (meaning 20-25C air with 5-15C water here--could be summer in much of the UK) it would be nice to wear something like a dinghy suit, with tight wrist, waist, and neck seals. Perhaps that's not so different than a dry suit, but it certainly easier to put on and take off, and to adjust layers. That might be the critical difference.
Remember, I'm not talking dinghies, with continuous splash. In water that cold I would be wearing a wetsuit or dry suit. I'm talking about larger boats that are probably dry much of the time. In a way, that makes the problem worse; warm air and cold water. A dry suit is only pleasant if it's really cold or if there is rain or spray on the suit.
Another thought is soft shells with effective wrist and neck seals. I once went for a swim wearing a softshell (Windblocker fleece) in 5C water. While extremely unpleasant, that neck seal made an important difference in terms of the shock. I was in the water for about five minutes (seemed much longer) but in fact, did not even chill the point where I was shivering. Fortunately, I was slightly overheated when I went in, so I doubt my body temperature had a chance to go measurably below normal.
Thoughts?
Thoughts?
