Puggy
Hello all,
Hopefully a simple question. I have two engine water temp gauges, one in the pilot house and one on the cockpit. Currently they have a switch to change between them. I want to wire them together so they read concurrently. If i wire them together in parallel, they both work but read 50% of the correct temperature. Thinking about this, i assume the temp sender has a changing resistance according to the engine temperature, and the gauges are basically ohm meters, and connecting two of them has altered the resistance in the circuit in some way. But my physics is struggling from this point on.
I am sure there is an electrical expert who could explain the principles and suggest a way of making it work? Can I add a resistor to the circuit? Or should i wire in series instead?
Thanks for your help
Piers
Piers
