Connecting Bonding Cables to Seacocks
Talbot
23 Aug 2003
Brighton, UK
Think you need to check this cause IIRC bonding seacocks on a wooden boat is not recommended. - assume yours is wood as bio just says gaff.
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day fluffc,
We normally solder a small 5 mm wide strip to the end of the wire and bend the top end out so that it can't slip out from behind the stainless jubilee clip, if you need to remove it often, then solder a spade fitting to the wire that will push onto the tang left at the bottom of the clip, then add a protective coating.
I hope this helps.
Avagoodweekend............
Old Salt Oz /forums/images/icons/cool.gif Growing old is unavoidable. However, growing up is still optional.
Talbot
23 Aug 2003
Brighton, UK
If it has never been connected and you are not suffering de-zincification, and/or are not trying to create a ground plane for SSB, why bother.
ashley
25 Jan 2003
\'d After Dark
Talbot, could you explain why you should not bond thu hulls together on a wooden boat.
Not contesting this, just curious.
Ashley...still learning.
<hr width=100% size=1>A truly wise man never plays leapfrog with a Unicorn
pvb
UK East Coast
Quite right...
If the skin fittings are good quality bronze, and are electrically isolated, there shouldn't be any need to bond them.
ccscott49
7 Sep 2001
If the seacocks are bronze, they dont need bonding, if they arent bronze and are fine, leave them alone. You could make matters worse, by bnding them, making a cell, because of different resistances in connections etc. Best to leave well enough alone. My seacocks are Blakes and are all independant, never (with lump of wood firmly in hand) had a problem with them and they are regulary inspected.
john_morris_uk
3 Jul 2002
At sea somewhere.
Agree totally. Last three boats we have had, I have spent happy hours taking the yards of decaying wiring out that (allegedly) bonded the through hulls etc together.
On our last wooden boat I also had to replace a length of strake underwater that had decomposed because of the electrolytic action of a misguided attempt to protect the prop with an anode.
On our current boat I wondered why the shaft anode erodes quickly, whilst next to a hardly eroding hull anode. Read the small print on Volvo engines "The gearbox is electrically isolated from the engine...." That will explain it then!
Anyway, I digress. Proper bronze through hull fittings often need no cathodic protection.
pvb
UK East Coast
Electrolytic problems in wooden hulls...
There's an <A target="_blank" HREF=http://www.mgduff.co.uk/Electro-chemical_decay_in_wood_vessels.pdf>interesting article</A> on this on the MGDuff website.
Talbot
23 Aug 2003
Brighton, UK
Others more erudite than I have already answered your query. My swiss cheese style brain had stored away the fact not to do it, but not why!
Talbot
23 Aug 2003
Brighton, UK
Re: Swiss cheese?
/forums/images/icons/smile.gif
