Dazzajohm
N/A
I’m sure most of you will have come across my recent tail of woe regarding my MS4 Gearbox in my recent post, so I won’t tell the story again.
Now the gearbox is apart, the guy tells me there are a few worn bits and pieces he will replace such as a spring which shouldn’t be a problem, but he’s also said the cone is worn and could do with replacing although not totally worn as it still has an edge on it.
I’m trying to find a replacement cone and it appears it has been replaced with two parts, one being 3858669 - sliding sleeve and the other being 3856502 - shoe. Can anyone confirm whether these are the right parts?
The engineer has also said that although it’s not a permanent fix, he could take a shim out to bring the cone closer together which should give me some more life out of the box. This means nothing to me, can anyone advise if it’s something worth considering?
