BrianH
How true that all is. Even in clear visibility, as anyone in the frightening situation of a fast catamaran coming straight towards you will know, it is difficult to know its exact heading. With a normal ship the prow lines up on the bridge and from a slow or stationary vessel it is easy to determine that it is going to be a close encounter. That is not always the case with twin hulls.I've had the utmost difficulty avoiding a collision in fine weather, with a ship that seemed intent on running me down at only 12 kts.
The only good thing about the speed in this case is that the fishing boat would have a fairly quick and clear indication of Condor's course on target trail, but what to do about it? Assume you have the Condor approaching on radar. You can't quite tell if he is going to pass close, but clear, and you know his ARPA can show him this. Do you wait, hoping this is the case? If you decide to move, can you decide which way? If he has seen you are stopped, he quite reasonably could pass either side, he has no aspect and you may move into his path, and unless he is prepared to slow or stop, cause the collision. No time for a VHF call, unless you just yell on 16 and hope. If you had more time I would suggest make all speed at his course minus 90 deg, showing him your portside, which clearly tells him he is the give way vessel, and try to inform him by radio. The driving issue is lack of time due to speed.
In the AIS screen shot below, the ship, a large catamaran ferry, was constantly wavering through 10 degrees (under autopilot?) but very clearly a threat - but which way to steer to get out of the way? To turn correctly to starboard (both under power) would be to probably place me directly under the bows at that closing speed (38 knots) and distance (1.1nm) as the CPA was, on average, marginally to starboard.
In the event, a channel 16 call to the named ship caused an immediate and definite change of course to starboard that cleared me by a significant margin.
