nimbusgb
nimbusgb,
I notice that the machine that you favour is dual action, most of the gurus that pronounce on this stuff recommend a straight sander polisher like the Silverline etc. and tend to denigrate dual action, though conceding that it may be less risky for a novice? What do you think?
Another question, the cheaper polishers like the Silverline tend to be about 3kg. while the medium price ones like the Dodo Juice etc seem to be only 1/2kg. lighter, is that going to make a lot of difference? I have a 250mm. angle grinder which I use mainly for cutting with a diamond blade, I guess it is a similar weight and I do not find it that comfortable to handle though the torque at high speed may contribute to that.
Dual action seems to be the way to go in car detailing and that is a very demanding ( and potentially expensive if cocked up ) market.
I had a friends clapped out MX5 to try things out on and within 15 minutes could get a cracking finish with the Dual Action and after an hours practice ( and a transformed MX5 bonnet, roof and drivers door ) I was confident enough to start on my Mercedes AMG. ( really must go and finish his odd MX5 one day!
Previously I have used single action ( not the silverline ) type polishers on high performance composite sailplanes where finish is critical. Not for the feinthearted and certainly not for a beginner. I wish I'd had a DA then.
A 1/2 kilo is going to make a difference on a boat as none of the weight is on the bit being polished and your arms are carrying the tool and applying pressure. Best advice is a light bungy cord attached fairly high up ( topping lift ) and adjusted so that it will make the tool almost weightless.
As to so called 'experts' denigrating DA polishers. Same mental attitude as people who thought GPS was the work of the devil!
