asabay
hope someone can help, what size of anchor do i need for colvic traveller 28, and what make is best ????
That is nonsense. No need for a 16kg on a 28' boat. The manufacturing recommends that size for boats between 34-44'.Yes, the Delta is averagely good. I've got one. To be on the safe side go heavier, say 15kg. You can never have too much weight in an anchor.
Without knowing what anchoring is proposed I'd say you can have too much weight as having a lumbering chunk of iron you hate manipulating will discourage use. When new most owners would have come home from the chandler lugging a 25lb CQR.Yes, the Delta is averagely good. I've got one. To be on the safe side go heavier, say 15kg. You can never have too much weight in an anchor.
Aaaaand, we're off!! Grab your popcorn, settle in to your comfy chair, let the fireworks commence....That is nonsense. No need for a 16kg on a 28' boat. The manufacturing recommends that size for boats between 34-44'.
What evidence do you have that it would be "better" that the manufacturer does not know about?
anchor on boat is a 8kg one of the guys says it's to small and to use it as a back anchor he says i should go for something in the region of 12kgI'm surprised there is not an anchor already on the boat. Tell us what kit is already on the boat, rope rode, chain, shackles, anchor and hopefully you will enjoy some sensible answers.
You will do yourself a favour, and the members here, if you tell us roughly where you are, where you are likely to use the boat and whether you only want an anchor for lunch or for overnight. As mentioned in previous posts how you will use the anchor will determine the advice you get. Being active on a canal is very different to the Thames and decidedly different if you live on the shores of Loch Ness
Because you are asking the question I assume you are fairly new to boatings.
As you might guess 'good' anchors cost more than ordinary anchors. Once you get a few replies here - try ebay, or equivalent or boat jumbles if you are on a budget. Do you have 'shops' selling second hand kit - try the 'for sale' and wanted section of the forum.
You will get lots of advice - distil the advice and tell us what suits you best and you will hopefully get the answers you need.
And
Welcome to the forum.
Jonathan
Years of experience. If you anchor in a force nine off Sheerness you'll be glad of the weight and be glad you didn't skimp due to silly advice!That is nonsense. No need for a 16kg on a 28' boat. The manufacturing recommends that size for boats between 34-44'.
What evidence do you have that weight has any impact on the holding power of the anchor? Have you actually tested your "years of experience"? Why would a reputable manufacturer recommend a 10kg anchor when you really need a 15kg according to you? When you anchored off Sheerness in a force 9, did you try first with a 10kg then a 15kg to see which is better?Years of experience. If you anchor in a force nine off Sheerness you'll be glad of the weight and be glad you didn't skimp due to silly advice!
Depends on the type of anchor and where you are going to use the boat. Anchors vary in design and some are better than others overall or in particular situations. The anchors suggested so far are good al round anchors and a 10kg would be fine for river coastal and estuary cruising. Keep the existing one as a spare or for use as a kedge (anchoring by the stern). However kedging is rarely necessary in normal anchoring.anchor on boat is a 8kg one of the guys says it's to small and to use it as a back anchor he says i should go for something in the region of 12kg
