scottie
I do recall that when mark laying at Scottish series in Loch Fyne we did display
️ As well as. ??????? M
You don't need to bother with NUC or RAM lights and shapes if your vessel is under 12 metres in length "except those engaged in diving operations". [Rule 27 (g).] This also implies that leisure vessels "engaged in diving operations" must display RAM lights and shapes, possibly as modified by Rule 27 (e).I disagree. The rules are quite explicit inasmuch as a vessel NUC is a vessel that due to exceptional circumstances cannot manoeuvre. If your rudder jambs and you jury rig another but it's fairly ineffective I suggest you'd be perfectly entitled to put RAM day shapes and lights up. Interesting as to how many yachts could actually do this!
I disagree.
Not sure this is up for debate,
I think you’re being too narrow in your understanding.
NUC is defined in Rule 3 as a vessel that through exceptional circumstances cannot manoeuvre as required by the Rules, hence RichardS yacht with a rudder problem is NUC and not RAM as she cannot be properly controlled to make extensive changes of course.
Rule 3 then further qualifies the NUC definition to RAM by adding "from the nature of her work". I suggest that "work" entails "reward", so a yacht or mobo transferring passengers or goods to another recreational vessel does not become RAM. Perhaps an ice cream boat or marina or chandler's RIB does qualify for RAM ?
The sense of "exceptional" means out of the ordinary, and not necessarily emergency.
One notes that RAM is for vessels engaged in launching aircraft, so perhaps flying a drone requires black ball/diamond/ball.
It is clear that recreational vessels engaged in fishing with rods/lines etc which do not cause RAM are not "fishing vessels"
I incline firmly towards the Fox's original suggestion that RAM is not for leisure craft, who should use normal lights or shapes, or NUC if there is any steering problem even minor.
Wholeheartedly agree with all of this except C and L define 'work' in the sense of 'operations' and that seems a far more likely meaning of the term in this context. So if and C and L are correct a Leisure boat can be RAM. Of course it's pretty rare that a leisure boat has to carry out "operations" of any kind.
I think C and L are right - work doesnt.always require payment - someone might work in their garden for instance, or 'work hard' on a run.
Interesting question.. I feel that the definition of RAM at least implies a distinction. Maybe it's the only bit of the Rules which can possibly be interpreted that way.The rules do not distinguish between leisure and ‘working’ vessels.
A yacht towing another yacht would still be able to steer out of the way of other vessels, eg in a head-on situation, so not RAM.Towing might qualify a yacht as RAM. Not being designed for towing, a yacht towing another could certainly experience difficulty in manoeuvring. A tug, on the other hand, owing to its special design, would not usually be RAM, although it could be if there were some unusual characteristic of the tow.
All these terms are well defined, without 'obfuscation', in the Rules, it's the 'intuitive perspectives' which cause the hang-ups..To me NUC sounds like it means the captain/skipper is unwell or washed overboard so cannot command.
I think it's badly phrased (regardless of what they mean it to mean) !
Whereas RAM could be be planned or unplanned (from a purely intuitive perspective)
The obfuscating beauty of COLREGS![]()
A private megayacht operating a helicopter should display RAM.
Yes, IF: the helo operations prevented her from getting out of the way of other vessels, as she would normally be expected to do by their masters.A private megayacht operating a helicopter should display RAM.
I will instruct my officers to bear that in mind in future.A private megayacht operating a helicopter should display RAM.
We did a hi-line exercise with a Sea-King from Culdrose, and yes the yacht (if possible) must motor in a straight line with the wind on the starboard bow, so unable to comply with the Rules.In that case a leisure yacht involved in a helicopter rescue may be RAM, I would have thought.
