danbhoy1888
I have a Leisure 20 yacht with Colnebrook Roller Reefing on my headsail.
I have been having problems unfurling the Genoa, I had to brace myself and pull hard on the sheet to unfurl it. I checked the furling gear for all the usual snagging problems and it seemed alright.
I decided to strip the drum and check the roller bearings, there were no rollers just a piece of nylon/plastic. Does anyone know if this is the correct part for this reefing gear or should there be a roller bearing. The drum moves freely enough when there is no load on it but as soon as I tighten the turnbuckle it becomes tight again,it has always been tight to unfurl and when I compare it to other R/R systems its to tight. The last owner kept the boat well maintained but I wondered if he put this nylon/plastic piece in because he could not source the correct bearing.
