pcatterall
The 'new' boats engine (Perkins 4108) does not seem to be as good a cold starter as the 4108 on my last boat.
There is 'heat' position on the key and I can see that it works ( whisps of smoke!) what is the optimum time to use the 'heat' position? can you overdo it? If the engine fails to fire up quickly has the heated fuel now been wasted and needs 'heating' again or what?
Is there a technique that anyone recommends like 20 " 'heat' and 10 seconds cranking??
I think in total it takes about 60" cranking to start does this mean that there is a danger of water backflow?
I have a speedseal plus impellor fitted, they are 'supposed' to suport a bit of dry cranking, would this be safe for this sort of start period.
Grateful as ever for the usual sound advice!!
