Cobalt drills
FWIW the best set of drills I've ever had are from Lidl's. They claim to be cobalt and suitable for SS and I've certainly had more luck with them than "genuine" cobalt drills bought individually from a local engineering supplier. At £5 or £6 pounds a set they've been excellent. Probably not as good as a £45 set, but I'm not prepared to spend that much on drills.
+1. I bought a second set for the boat. I've used them on S/S very successfully with a spot of cutting oil. They come in 0.5mm size increments, which I find useful.
This article is worth bookmarking
"Stainless steel material is however susceptible to a phenomenon called work hardening which is one of the reasons this material is difficult to cut and drill. Work hardening is the result of the action of cutting edges deforming or compressing the surface of the work piece, causing a change in the worked material's molecular structure that increases its surface hardness. .........."
The full article Tool Tip: Drilling in Stainless Steel
http://blogwithtravers.blogspot.com.au/2013/02/tool-tip-drilling-in-stainless-steel.html
However, we can also make work hardening work for us, rather than against us. Very many boat fittings such as bottle screws, tangs, chain plates, bolts and many others are cold stamped, which work hardens them and increases their strength considerably. Perhaps the best example is stainless steel wire, which is cold extruded. A reduction in surface are of only 3% in this process multiplies the strength of the annealed metal by three or four.
Incidentally, beware of statements like: 'causing a change in the worked material's molecular structure'. Work hardening can be seen in a normal metallographic microscope, it is due to the accumulation of dislocations in the crystal structure. Molecules are about a billion times smaller.
I've still got my 1/2" HSS drill set my dad bought me 40 years ago (well, most of them), increment is 1/64"
I had a rule: only drill the initial hole with multiples of 1/8", then you rarely need to sharpen the intermediates.
Also got an AF socket set from the same era, but the case is almost rusted away. Used it last week.
Now I feel old.
I'll leave Sailorman to explain! Drill sharpening is quite an art (and one I have to say, I've only ever had limited success with). There's the angle of the "cone" as you look at it from the side, but there's also the "rake" angle on each of the flutes. At almost microscopic level, (easier to see, the larger the drill is), when you look at each flute, it obviously needs to dig into the metal that you're drilling and "shave" a piece off, so the angle if you look at a cross section through each flute from the side is also important. That said, all other things being equal, cobalt drills are just "better" in my experience.
You can buy drill sharpening machines (of various quality). They usually have a flat grinding wheel and a holder that holds the drill bit at the correct angle to it. Most have more than one operation because there's more than one angle to get right.
The rake angle is very important, different angles for different materials, which also have recommended cutting speeds depending on the material, there are engineering tables for this. Some materials require a negative rake for best results, such as brass, cast iron, negative rake is achieved by grinding the cutting edge of the drill approximately at 90 deg. to the edge, just a touch on the grindstone is sufficient to produce the negative rake required. Similarly when turning on a lathe the cutting tool is ground negatively for those metals, quite different for s/s and mild steel.
Lubricants are important for both cooling and cutting efficiency, engineering shops still use a milky coloured oily 'mistic' as it used to be called anyway.
If you want to help cutting s/s try some spit, works well, also with other steels, some on your finger applied to the drill
I recently made a few exhaust flanges out of 8mm thick 304 Stainless steel, I cut the holes using a 35mm Starret hole saw at slow speed using my bench drill and a bit of lubrication. I make 5 of these plates with a lot less trouble than I expected. Slow speed, and make sure the cutter keeps cutting and not just skidding on the surface.
I like to check my drills with a powerful magnifying glass before drilling stainless. It must cut immediately to avoid the risk work hardening. Usually a quick rub with a Easy Lap diamond sharpener is sufficient.
I have not needed to do this, but if work hardening has occurred, it may be possible to remove it with a Bremmel fitted with a diamond tip.
I use these from Screwfix http://www.screwfix.com/p/erbauer-ground-hss-drill-bit-5mm-pack-of-5/65352 They also do a bulk pack of 150 assorted sizes for about 50 quid. I use them in my day job and find they last as long as more expensive bits and I drill a lot of holes.
Drilling stainless is more about technique than anything. I've drilled stainless with cheapo "Jobber" bits. Keep it slow and don't overheat the bit.
I use a regular drill bit when working SS. The trick is to run the bit at a low speed 1500 rpm around that, keep a steady firm pressure and hers the real trick, keep a steady flow of water to cool the bit. Oil will not work as it burns off. I use a little squirt bottle with water in it to shoot water at the bit as I am drilling. Do this and you will think you are drill mild steel and your bit will last for a surprisingly long time before needed sharpening. One of these days I need to make a video of this. This does work
Capt. Wayne
I occasionally watch the TV shopping channels. There's an advert for drills that look like masonry drills, but they use them to cut through several materials, including a steel file. Always been a bit sceptical myself.
There was always a man at LIBS selling drills that would cut files and almost everything else. They always looked pretty impressive but when I finally went to buy some he was no longer exhibiting. I understand he retired a few years ago.
