Rum_Pirate
Of the three to choose from I prefer # 2.
Also happened on mine, there was significantly less metal remaining when viewed from underneath, even though they looked fine from above.That happened on my old Hallberg-Rassy. I fitted the replacements on sealant on top of a thin sheet of nitrile rubber. No problems afterwards.
Fraid not.
Centre line fixings will create a rocking effect which would be more crushing to the deck than four-hole fixings.
I like No 1 for the 4 hole fixing. I would further query if it is necessary to use lots of turns to secure a lineI don't like number 1...... not enough space and not as smooth edges as other two . I like number 2...... lots of space and easy to bolt down. Number 3 is better than number 1 but not as good as number 2. Only my opinion.
I changed them to s/s to match the bolts..I was replacing the cap rails so new holes were not an issue.
