Cleaning flexible water tanks
rogerroger
11 Jul 2001
West Sussex
www.myboatdetails.com
I removed my Plastimo 100 litre flexible water tank and brought it home to try to determine why the water tastes so bl**dy awful in a one year old tank.
There was various slimey gunk inside which seems to have come out with a good flush with the hose pipe. However, as the water is flushing through I think I'm seeing slight traces of oil. I did have a problem with a spilage around the tank and it's possible some got in.
How should I clean it ?or should I bin it and buy a new one ? (a bit loathed as this one is nearly new)
cheers
Roger Holden
www.first-magnitude.co.uk
Piers
2 Jun 2001
Guernsey, Channel Islands
www.playdeau.com
Roger - see the thread under the Motor Boat Chat forum, dated Friday 23rd Nov entitled Drinking Water posted by boatone. This should give you a clue as to what to do - and call Dave Street if in doubt (his contact number is in the threads).
A clue to keeping it clean, once it's clean, is simply to keep it well used. I, at least once a month, flush my water tank well through - hose pipe stuffed deep down into the tank and let it overflow/flush for 5 mins.
Piers du Pre
MBM Cruising Club enthusiast
www.dupre.co.uk
david_bagshaw
5 Jun 2001
uk
Milton wont remove oil, but if you fill & soak tank with washing detergent & slosh round, rinse ,& rinse & rinse , then milton it, it should be ok. lastly a hand full of ordinary portland cement, puts a calcine cover over the surface, Was used in the days of bitch painted tanks of old.
hope that helps
David
www.yachtman.co.uk
steve
Barcelona
Yes, exactly. However, the preferred method is not flushing, but soaking. A solution of vinegar and water left to soak for two weeks! I don't remember the concentration, but it's in the Vetus catalogue or I can find it for you if you're still interested.
VMALLOWS
9 Oct 2001
Emsworth, Chichester Harbour, UK
Roger, in addition to all the other remedies, may I suggest CHEMPRO a popular cleaner/steriliser in the home brewing market. Its essentially the same as 'Sterident' ... an oxidiser. Leave it in overnight and flush well...amazing what it removes.
Personally though, I replaced the flexibles with Stainless...saves the leaks as well.
