Hi I have been given a Chinese rectifier is it also a voltage controller the instructions are not clear. I will attach a screen shot of the Amazon sales details, has anybody used one of these if so what does it actually do.
Thank you all, I have read the instructions on the Amazon site, but where it sais stop the turbine to prevent battery damage when fully charged, does that mean when the batteries are full, I should stop the turbine or does it mean it will will stop it and restart it when the voltage drops? The way it is written it sounds like a command rather than a stating that it will control the turbine according to battery state of charge.
Mike
I think OP would do best to open up the regulator and see what is inside.My experience witha friend's Chinese wind gen was the despite claims the box was a regulator it simply contained 6 diodes (a 3 phase rectifier) Voltage was totally dependent on wind speed and was pretty poor at actually putting current into a 12v battery. The power claims were obviously for output at 12v not 14v. I did manage to improve the output by replacing the diodes with schotky type diodes (lower forward volt drop) but the whole generator dismantled itself in a strong wind in the end.
Now I note that this "regulator" has wires for braking the turbine. This however can be done fairly easily by shorting out the 3 phase output. Perhaps with a relay for all windings . I am not sure about that. Or perhaps just one winding shorted out. If OP has only been given the regulator box then I can't imagine it being much use for anything but rectifier for a 3 phase gen. olewill
Nahh, thats just chinglish for you.. Consider the first bullet point "Convert AC current to DC current so the AC turbine can be connected to battery" > do you think this is an instruction for you to convert ac to dc?
Why, when the Chinese presumably invest in design, manufacture, advertising, packaging etc, do they not spend a few more dollars to achieve better translations?
