bedouin
In the first case, in almost every case one of the vessels would be overtaking but I agree that there could be cases where risk of collision exists but it is not clear which vessel is stand on.What if two vessels are on parallel or diverging courses, and one of them tacks under the bows of the other?
But let's also go back to the narrow channel case -- do we all agree that a sailing vessel should not tack under the bows of another vessel coming up the channel, so close that a crash stop or hard maneuvers are required of the other vessel?
In the second case I think what we established was that tacking at the edge of the channel is effectively making no change in course so if you are stand on vessel that is fine (in fact you are obliged to do so) - and the other vessel will have given you plenty of room. If you are give way vessel then you shouldn't get yourself into that situation - you should have chosen to take action earlier.
I think I understand what you are trying to get at but I don't think you can construct a reasonable example without at least 3 vessels involved, probably more.
