Dockhead
I understand the point you are trying to make - but let's turn it around and ask what you would have done had you been the skipper (and for the sake of argument let us assume starting the engine isn't an option - that is another discussion entirely). In those conditions neither luffing nor taking way off the boat on that tack are feasible - the only way the boat can be stopped safely would be to tack then rather than sheeting in, let the sheets fly while pointing about 60-90 degrees to the wind - but to do that would violate the stand on vessel's obligation and make collision more likely
We're talking about the boat-handling question.
I would have brought the boat head to wind (which seems to have been blowing, gently, right down the channel) just as I reached the edge of the channel, and luffed up. Thus staying out of the way and letting the mobo pass by. Why do you think luffing up wouldn't work? You have to do it early enough to let the momentum dissipate, but if you are watching the mobo and thinking ahead, I don't see why that's a problem.
As I luffed up, I would have started the engine to give myself more maneuvering options (I realize in your hypothetical that this is off the table, but just for the record). If I were concerned about momentum carrying me into the moored boats, maybe not having enough time from start of the maneuver, I might take a more vigorous action and tack into a hove-to position at the edge of the channel. Different boats handle differently, I realize, but on my boat and in my hands, I can put the boat right onto a pontoon under sail with that maneuver, such that I can step off and tie up single-handed, so I can control the position of the boat within less than a foot, and the moored boats are no problem.
I would certainly not let sheets fly, which would give up control (and flog my lovely carbon laminate sails, new last year, God forbid!).
Does any of that violate required action of stand-on vessel? I'm not sure it does -- we have different interpretations -- but we don't have to get to that question -- because by placing the vessel at the edge of the channel out of the way, the risk of collision is eliminated, and as Uricanejack correctly said, you can violate the Rules to achieve such a result.
I think the main thing is watching the mobo and anticipating what he is doing. If he is barging along heedlessly, and you cannot discern any intention of giving way, then it's possible to form a pretty good idea of where you can be, where he won't be, and thus avoid the collision.
I think you said something yourself about "predictability" -- this is key. This is why we are obligated to stand-on. And if some other vessel is plowing ahead heedlessly, that's actually much less dangerous, than one maneuvering randomly. I don't think that it would have been that hard to get out of the way of that mobo.
