Daydream believer
I replaced the one to the heads outlet at 5 years because I did what I do every year- go round & tap them all & give a good heave on the seacock, then make sure the valve operates freely, by opening & closing them quite a few times. It was actually the elbow after the stopcock that disintegrated so I could always have shut the valve in emergency- If I had been on board & aware of the issue. In any event I replaced the whole assembly.Does anybody routinely replace the seacocks on their boat every five years?
I replaced it with DZR. I suspect that all the others fitted by Hanse are DZR. Forumites are talking about brass but i suspect that they will find that the manufacturers have actually fitted DZR & they are talking b..x about brass being used wide scale. True the odd one may slip through- as my one did - but it only needs testing annually. Mine appear fine at 18 years & I have no immediate plans to change them.
However, when I do they will be True Design. That being said, I will do some research first, as I have seen some feedback of problems with True Design. But that may be hearsay, so I will hold on that one.
